car overheats, then goes to cool then overheats
Posted: November 21st, 2003, 12:27 am
hey,
i was reading through the forum for about 2 days now and i could not find an answer to my question. So if anyone could help i would appreciate it. This is all i know . . .
I have a mazda mx-3 year 93. I have a new water pump, new timing belt and a/c. There are two fans in the car, one for the ac and one for the radiator or engine im assuming. When i turn the a/c both fans, the one in front of the engine turns on and the other one does too. However, my car has been overheating the thermostat says. It goes pass the h ( heat ) symbol and then will eventually drop between the c and h symbol. I dont know what could be causing the problem. I changed the cooling fan switch. It did not fix the problem. If anyone has n e idea on how to fix this or wut may be the cause to this problem i would greatly appreciate it. Thank you
