How to take off my head light cover?
Hey I just bought new Halogens for my head lights. With my old car I was able to unscrew the lens and screw it back on. With my 93 MX3 all I see are these clips and I am not sure how to take them off? Second question is, if I can just un clip them when I put them back on do I need to apply and type of sealer? If so what should I use? Thank you for any1 that can help me out.<P>Ash
- Andrew_Pakula
Re: How to take off my head light cover?
To change the bulbs, the bulb is attachs to a housing that screws/turns into the headlight. To take out the light you simply have to turn the housing part of it and pull it out. Putting it back in can be a bit trickier but its the same process. Be careful when you switch the bulbs, don't touch the surface of the bulb because if you get any grease from your finger prints on it then the bulb can explode later.
In other words, you have to open the hood and do it from the inside. Once you look there, it will be pretty much self explanatory.
