polished valve cover
Posted: March 4th, 2002, 9:12 pm
by mazdamxstyle
hey guys plz dont bash me for asking this but how do I polish my valve cover once its taken off? i want to give my engine a much cleaner look instead of just painting it i wanna polish it. what things do I need and how much are they? any info would be awesome thanks guys!
Re: polished valve cover
Posted: March 4th, 2002, 9:35 pm
by MAZDASPEED STEVE
You're gonna want to start with a couple sheets of low grit sandpaper(100-200) and work your way up to a higher grit sandpaper, basically wet sandpaper(1500-2000). It'll take a while and will be kinda tricky getting into all the grooves and corners, a die grinder would help alot and cut back on time. Good Luck. :D
Posted: March 5th, 2002, 1:00 am
by VizualXTC
I'd get it professionally done.
Posted: March 5th, 2002, 3:26 pm
by mazdamxstyle
after a days worth of sanding whats the next step? i just need a little more info but thx for the help so far. ;)
Posted: March 5th, 2002, 11:21 pm
by blikmik
I polished mine... trust VisualXTC.... get them professionally done... it's not that much $$$ and saves you a HUGE amount of time!! By the way ... they do look sweet when they're done.. I accented mine with powdercoating around the emblem!!!
Posted: March 6th, 2002, 1:31 am
by mazdamxstyle
what type of shop and how much does it cost for a professionally done job?
Posted: March 6th, 2002, 2:51 am
by mrprecidia
i had my two valve covers and my intake manifold done for about 300 cndn. you take them to a polishing shop look in the phone book.
Posted: March 6th, 2002, 7:05 pm
by blikmik
Also chroming/plating shops do polishing as well..
