How to take out Back lights
I need to change my reverse light bulb and I can't seem to get the lens off. I've taken off the three screws, but I can't get anything off after that. Do I have to take off the lens from the housing or do I pull the whole thing out with the housing. It seems to be stuck!. HOW???? Its driving me nuts.
hi
- monty73741
Re: How to take out Back lights
take all three screws out and pull in a kinda inward direction.......<BR>youhave to pull kinda hard<BR>jason
Jason Danaher
Please Help Support MX-3.com
to remove the tail lights, you have to remove the two top screws and the cover comes off... then you remove the big screw from the rear...<P>then all you have to do is slide the light away from the centreline of the car...<P>simple and painless.<P>cheers,
there are 4 clips behind the lights. You just have to pull the light hard for them to pop out. The clips go back in easily. you dont take the lens off you take the whole light assembly out.
