pcv valve on a BPT
pcv valve on a BPT
anyone knows where the pcv valve is on the BPT motor and what pcv valve should i buy <p>thanks for the help
http://www.cardomain.com/id/phil_costa
<img src="http://smkclan.com/images/snake/articbeast.jpg" alt=" - " />
Re: pcv valve on a BPT
sticks into the upper left corner of the valve cover.<p>Use a Protege BP PCV valve, they all use identical replacement parts including gaskets, timing belt, etc.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
ok someone told me to get a new pcv valve to get a better gas consumption is that true ??<p> so you hare saying i should buy a <p>pcv valve from a Protege BP (what year)<p>thanks for your help
Should be about the same years as the motor.. 90-94
-torp.
I don't own a Mazda.
