"24 VALVE DOHC" VC on a ZE?
I'm about to buy an extra IM to be ported and the seller has sent mesome pics. In the pics the front valve cover has the "24 valve DOHC" on it. I have not seen a ZE with this valve cover on it before. I'm thinking its a A-spec motor. Have any of you seen a J-spec motor with this valve cover?
What do you guys think.
65 shot > V8
- papa roached
Re: "24 VALVE DOHC" VC on a ZE?
the KL-ZE with that VC comes from a Xedos 9, you can pull one from a millenia like i did
<img src="http://memimage.cardomain.net/member_im ... 9_full.jpg" alt=" - " />
<small>[ November 21, 2004, 04:17 PM: Message edited by: papa roached ]</small>
I looked at your car earlier before posting and I swear I did'nt see that VC. What is the number on your TB, it should be KL something. For example mine is KL68.
Thanks for the reply.
65 shot > V8
- papa roached
im sure its KL68, its not KL31, those are on the straight neck, that pic is on the last page, the other pics dont have it on there cause i cahnged the VC to that, thats a straight neck KL-ZE with a millenia intake and vc on it
- Zoso124
To my knowledge if it has that on the front of the valve cover the engine was built 97 or 98+
Mike Evans
Gone:
Gone:
- papa roached
well, the way to tell is the little tube on the front, if it dont have it, its a 97+ motor, if it does its earlier, again that VC on mine didnt come on it, i put it on
it seems the eunos 800's / millenia have the "dohc 24-valve" on their valve covers. I saw a 95 millenia the other week at the yard and it had "dohc 24-valve" on the front valve cover with NO "mazda", weird.
The MS8's (at least my ms8 ze) had just "mazda" on their valve covers :-/
might be different from year-to-year![Shrug :shrug:](./images/smilies/shrug.gif)
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Mine has it too. It is a ZE curve neck.
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
But if someone can be fooled into it being a ze that easily lots of people would be just switching valve covers...
This motor has the PVC tube on the front valve cover. Papa Roached, is that an A-Spec millenia IM?
65 shot > V8
- papa roached
that was pulled from a 1997 Millenia in North Carolina
