k series engine information
- Kokiriwave
Ok, I'm trying to get as much information on the k-series engines as I possibly can. This is what i want everybody to do. I'll ask a question. answer it, then ask your own question. If your question isn't answered quote yourself and type bump under the qoute. If you know everything (LOL) ask a question with the answer under it.
Here are my questions:
1) When did mazda first start producing the K-series family?
2) What engines belong to the family
3) What are their HP and torque numbers?
bump
<small>[ November 07, 2004, 04:22 PM: Message edited by: Kokiriwave ]</small>
bump
I want MAZDASPEED!
MY WEBSITE:: http://kingmx.net
- fry_81
Re: k series engine information
The K-series comprise 2.5-litre V6DOHC(KL), 2.0-litre V6DOHC(KF) and 1.8-litre V6DOHC(K8) engines.
You should check out this site- http://www.rs-productions.com/RSP_Motors/tech/sae-920677/sae-920677.htm it should answer all your questions.
- babyblueMX3
and 2.3 KJ engineOriginally posted by fry_81:
RIP 400whp ZE-T MX-3
- Kokiriwave
ask questions, ANYTHING
I want MAZDASPEED!
1.) Is turbo charging a K8 a good idea?
2.) Whats the most known problem when a K8 reaches 100k miles?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
turbo charging anycar is a good idea:) why? cause its fun:P
at 100k miles depending on how you drive your car and weather you have turboed it. CV joints might go, umm lifters will start to make noise.
I planning on doing an engine swap (as everyone else I suppose) either KL_ZE or KL_DE, and I do have one question.
Is there any difference in the parts of the two engines? i.e. Do I have to special order any parts that may f*** up in the KL_ZE directly from Japan?
My friend's installing an 3GTSE engine in his MR2 MK2, and I can't let him have all the fun right?
babybluemx3: Nice ride!![2 Thumbs Up :2thumbsup:](./images/smilies/2thumbsup.gif)
<small>[ November 08, 2004, 04:22 AM: Message edited by: verzutiko ]</small>
'92 GS
My worklog
My worklog
- fry_81
nope, finding parts isnt a problem. if im not mistaken the klde is from a probe gt. so if anything finding parts would be far easier as probes are much more common.
There are only two KLZE parts you can't get new here. That's the pistons and the cams. Everything else is identical to a US millenia motor.
91 Eagle Talon Tsi AWD *RIP*
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- papa roached
werdOriginally posted by TsiMiata:
Anyone clicked into the "Outlaw Engineering" advertisement on the top of this site?
If you have, what are your opinions about that product? Worth the money?
'92 GS
My worklog
My worklog
- babyblueMX3
don't worth it IMO (before you ask yes I have them)..but stick to the thread please
- Kokiriwave
Whats the difference between the KL engines and the KF? compression wise? which is more boost friendly?
I want MAZDASPEED!
Is the search function like broken or something? All NA K series have a low compression version and a higher compression version.Originally posted by Kokiriwave:
