Mazda Doors
Posted: October 16th, 2004, 6:41 am
by N_Mazda_L
Hey. Sorry if this topic is a little off topic but i thought it would fit best here(i search the rest of the forum top to bottom but i didn't find anything very well said about it).
I'm re-doing the doors in my 93 mx-3 GS. i took the fabric off the driver door and found a black film above the foam. Do I have to take this black fil off as well as the fabric? or would it be better for me to leave it on? Any response would be better than no response.
Thanx,
A confused Mx-3er
Re: Mazda Doors
Posted: October 16th, 2004, 7:30 am
by Nd4SpdSe
Actually, the "Appearance" forums would have been the area to post this,
Re: Mazda Doors
Posted: October 16th, 2004, 8:15 am
by perhapsadingo8yerbaby
Take a look at Barry's how-to for this project. http://www.barrykclark.com/doors.htm Doesn't completely answer your question but still has relevant info. The biggest risk is that you'll end up with an uneven sub-surface after removing the black stuff and if you don't remove the black stuff, I'd be concerned that a nicely done glue job still won't hold up over time because the foam backing can/will break down with age.
I'd either sand the panels clean of all foam before application of the new covering or consider adding a fresh closed cell foam underlayment and to hold the new covering snugly, "tufting" it with matching covered buttons anchored through to the panel backing itself. This is a common upholstery technique and is the approach I've been considering after talking to a local auto upholstery shop. Otherwise, the difficulty working with the inside angled curvature of the panel could leave you unhappy with the results. Personally, my ride needs freshly covered door panel insets but I never want to have to do that project a second time...
<small>[ October 16, 2004, 07:17 AM: Message edited by: perhapsadingo8yerbaby ]</small>
