klze misfiring, bogging, backfiring
Posted: September 25th, 2004, 6:18 am
by cozmo959
i went to the tracks with my ze the other night. everytime i floored the gas, once i hit 6000 rpm it would bogg down and backfire. i would have to let out the case and then floor it again but at 6000 rpm it would happen again. my friend spectating said i had a lot of black smoke from my exaust. it only happened at 6000rpm and up. i adjusted my safc 2 to lean out the fuel mixture thinking it was to rich but it only helped out a little. could this be my timing or does anyone else have any suggestions. this never happened before an i assumed it must be timing cause i just serviced the water pump and timing belt. thanks for your help
Re: klze misfiring, bogging, backfiring
Posted: September 25th, 2004, 6:48 am
by Talon_66
What ECU are you using. I have a similar problem becuase Im not using the KLZE ECU
Posted: September 25th, 2004, 9:02 am
by cozmo959
i have the kl-36....its the right ecu
Posted: September 26th, 2004, 8:28 am
by cozmo959
anyone?
Posted: September 26th, 2004, 12:39 pm
by papa roached
what vaf
Posted: September 27th, 2004, 4:53 am
by cozmo959
the k8 vaf
Posted: September 27th, 2004, 11:25 pm
by killerpickle
is it a coincidence that the last vris setting is at 6250? (both closed)...
i got nothing sorry
Posted: September 28th, 2004, 2:55 am
by ZEmadman
is there a way to disable vris so that you've got max airflow at all times? or is it better for it to be on?
Posted: September 28th, 2004, 3:44 am
by papa roached
with the VIRS on it will give you better mid range power but with them off you will get a bit more up top but every thing i have seen says keep the VIRS there cause you will lose alot in 1/4 mile times and that means you dont gain anything
Posted: September 28th, 2004, 5:51 am
by IanL
The VRIS
ensures you get maximum airflow by tuning the induction tract to minimise inertia effect on the moving air.
Less inertia = More air into the cylinder
Posted: September 28th, 2004, 1:44 pm
by Gro Harlem
i had a similar problem. the car would stumble at about 5000 rpm and then it'd accel fine past that.
I replaced both O2 sensors, and now the car runs flawless.
Posted: September 30th, 2004, 12:38 am
by Chasing_Size
Had the same problem.. bad vaf, replaced vaf with new one, runs like sex.
