Magnetic Oil Drain Plug's on ebay....
DJsMX-3
Post by DJsMX-3 »
Well im qurious if theese could actually hurt anything and if they do have a positive effect..
If the magnet actually is strong enough i can see how the metalparticles would cling to it,but im a little worried if it allso could have some sort of negative effect on the engine :)
Take a look:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7923297190&rd=1
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
mmac
Re: Magnetic Oil Drain Plug's on ebay....
Post by mmac »
I can't really comment on their use on car engines, but I have seviced aero gas turbine engines for a number of years and they make extensive use of magnetic sump plugs in the oil sumps of the engines and any ancilliaries that have oil lubrication. These were used more as an indicator of impending component failure(the metal particles & oil samples were then sent to test dept to establish what component they had come from, or the component was changed ) rather than as a means of preventing metal particles circulating through the engine(that's what your oil filter is for).
<small>[ September 24, 2004, 01:24 PM: Message edited by: mmac ]</small>
1994 MX-3 ZE
mitmaks
Post by mitmaks »
they're worth buying.
IanL
Post by IanL »
I agree with mitmaks, they are good, and will not affect the engine in any way. The oil filter doesn't catch everything.
kenped8
Post by kenped8 »
I have just changed oil on my girlfriends Suzuki and it has one these plugs. It had some oil/metal-splines on it. I think it is a very good idea to use these.
Klze,CAI,Exedy clutch, HM Engine mounts, HM ss exhaust system,Cobra lowering springs, 18" wheels.
DJsMX-3
Post by DJsMX-3 »
My initial thought was allso that it was a good thing,but you never know everything and my knowledge about cars is only what i have learned along the way :)
schuttie2002
Post by schuttie2002 »
For god sake dont spend 8 bucks on one of these. take the dimmesions of the drain plug to autozone and you can pick one up for 1.89. did it last oil change and this time it came out with a few shavings. definatly worth 2 bucks to potentially save a thousand
DJsMX-3
Post by DJsMX-3 »
Thanks for the advice schuttie but i defenetly think the planeticket to my nearest autozone would be more expensive than ordering through ebay ;)
I was only using the link to ebay to show what i meant,and i wanted to hear if theese things are any good..
