temp. sensor swap on klze
Posted: September 23rd, 2004, 7:38 pm
by jordan69
i was wondering about the fan thermosensor that you have to swap over to the KLZE. i just need to know what size hole i need to drill to put the new sensor in and what size threads i need to tap into hole to screw in the sensor?
Re: temp. sensor swap on klze
Posted: September 24th, 2004, 1:12 am
by kenped8
Drill hole size is 10.5 mm and tap is M12x1.5. Remember too use alcohol when tapping and not not oil or grease as it is aluminium. Good luck! i`ve just done it.
Posted: September 24th, 2004, 1:46 am
by mdavis
Make sure you collect the filings that drop...
Posted: September 24th, 2004, 9:37 am
by jordan69
k, awesome, thanks guys.
