Re: 17 LHO2S inversion error
Posted: September 20th, 2004, 4:37 pm
According to the book, Code 17 is termed Closed Loop System (Left side), and is called when the left O2 sensor does not change its output by 50 sec after the speed exceeds 1,500rpm (I guess this means after starting or pulling away from a stop).
The possible causes, apart from the O2 sensor and wiring, are:
clogged fuel return hose
Clogged fuel hose between pump and fpr
defective fpr
defective engine coolant sensor
your old friend the vacuum leak
defective fuel injector
defective wiring to fuel injector
defective ECU
defective fpr
defective ECU
