altezza tail installation?
Posted: August 16th, 2003, 1:11 am
by mx3zoom21
does anyone know how to install altezza tails on a mx3??? please respond with directions
thanx
zach
Re: altezza tail installation?
Posted: August 16th, 2003, 2:22 am
by JasonH
Installation is reverse of removal. For removal see The FAQ.
Posted: August 16th, 2003, 11:59 am
by 2fazed
I think there are only three screws. One on the outside and two on top, but you don't need to take the top ones off.
Posted: August 16th, 2003, 9:00 pm
by BADMX3
undo the screws then tap the lights outwards to take them out then reverse the process to put altezzas in.<p>make sure you seal them first though bro! put a layer of silicone around the joint <p>> once you start the job it takes around ten mins
