Check engine light or cruise control
Hey I have a 96 GS and the check engine light is on. I have tried to jumper it between ten and ground, but all that does is make my fan turn on and the CEL stays on. I took the car to a shop and they said it was a cruise control servo malfunction. I hav enot had a problem using my cruise control since the CEL came on. Any ideas?
Re: Check engine light or cruise control
It's normal for the fans to come on in diag mode with ignition on and "TPS off" (I think this means throttle closed & TPS switch in idle position) - I think it's a test facility for the fan control.
If your car is a '96 I assume it's imported from Canada, and is OBDII - in which case the diag codes cannot be read with a lamp in diag mode, an OBDII code reader has to be plugged into the diag connector 2 which is under the dash on the driver's side.
<small>[ September 01, 2004, 04:32 PM: Message edited by: IanL ]</small>
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
Thanks for the info, and yes the car was inported.
