Oil Capacity...1.8 vs 2.5?
Just wondering, do the KLZE/DE's actually take more quarts of oil as compared to the K8?
Re: Oil Capacity...1.8 vs 2.5?
K8 and KL are the same - 4.2 US quarts (4.0 litres), including filter change.
Same. Though 4.2 qts sounds low. I swore it was higher. Anyways, I put a full 5 qts in with my ZR1 oil filter, and the dip stick is still within spec.
do you know the zr1 oil filter parts #
you know like fram's oil filter for mx-3 is 6607?
or what year i can look in the books for and what size engine
sold the mx-3 , bought 04 gtp comp g , from the smallest v6 to one of the biggest 3800 s/c FTW
Don't use Fram. They are cheap. The WalMart brand filters test better than Fram. Anyways, look up the 1992 Corvette ZR-1 --- not the regular Corvette, the ZR1.
I stopped using the ZR1 filter after the gasket leaked. It doesn't contact 100%. I found that the Ford Festiva filter (mazda engine used in those things) which is the same as basically ALL honda D & B-series engined cars is larger & has the proper gasket for our engine.
If you really want to use the ZR1, look up "32-valve corvette". i found they are usulaly listed as 32-valve instead of ZR1 in most of those filter books.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Hi,
I`ve also installed a bigger one, manufactor is
MANN Filter, part number is W825/80 (Datasheet:
http://www.mann-hummel.com/mf_prodkata_all/sdaevska06.hbs?prdsl=1506&lang=E®ion=1 )
original is W610/3(Datasheet: http://www.mann-hummel.com/mf_prodkata_all/sdaevska06.hbs?prdsl=3081&lang=E®ion=1 ).
Filter is used in Mazda B-Series Pick-UP, 2.2l
Engine , built 01/78 - 12/84 .
Greets
TK
Greets
TK
