Automatic to manual swap? Any different from the FAQ?
The FAQ says its for an MX-6 or PGT....is there any difference for the 3?
what kind of car IS that?
- PATDIESEL
Re: Automatic to manual swap? Any different from the FAQ?
Not really there may be some minor differences, but should be basically the same. We (MOCA) are doing one for the President ,Atlanta MX-3, Labor Day weekend, so if you have any more questions just ask on our forum. Or after labor day we should know exaclty, but I don't anticipate any problems at all.
You'll need to use MX-3 manual trans axles as (I believe) all others are the wrong length.
