kl36 camshafts into curved neck ZE
Posted: July 22nd, 2004, 1:51 pm
by MX3ze@7psi
has anyone done this yet?? If you had effects does it have?
Re: kl36 camshafts into curved neck ZE
Posted: July 22nd, 2004, 2:04 pm
by babyblueMX3
never heard of kl36 cams..what car did it came out of??
did you mean kl31 cams?
<small>[ July 22, 2004, 01:12 PM: Message edited by: babyblueMX3 ]</small>
Posted: July 22nd, 2004, 7:53 pm
by mdavis
Yeah it's KL31 or KL01. I have KL01s but I can't find KL31s anywhere...
Posted: July 22nd, 2004, 9:11 pm
by babyblueMX3
they sell regurlarly on probetalk...but you know they've been dyno only 4hp over kl01
Posted: July 23rd, 2004, 9:51 am
by papa roached
i think the only big difference is it changes the power band higher up in the tach with the KL31s
Posted: July 23rd, 2004, 10:46 am
by MX3ze@7psi
yeah sorry its kl-31 cams. So then its not going to make any differnce with the cams? I still say my old KF-ZE pulled alot harder. My KL-ZE lags very bad in first and second gear then goes on third though. I'll still using the K8 intake mani and K8 ecu. I've tried the KL-07 ecu and alittle better but it still slow on first and second gear. Are curved neck ZE's high end power only or what?
Posted: July 23rd, 2004, 10:51 am
by papa roached
from my understanding most curved neck motors (KL01 cam) make their max torque about 500-1000 RPMs sooner than KL31 cam motors
Posted: July 23rd, 2004, 10:52 am
by babyblueMX3
yeah most high power..but when I had my k8 IM on my ZE, it was like if the car was lagging like you said...I would still suggest to you to get the millenia manifold
is you exhaust stock?
Posted: July 24th, 2004, 12:31 am
by MX3ze@7psi
I have the millenia mani but couldn't use it because I had to send back the throttle body cause it was all bent up from shipping and also the fuel rail is cracked. My exhaust system is stock except for a punched out cat and a muffler. I was thinking about getting a 2.5 custom bend from the cat all the way back to the muffler.
Posted: July 24th, 2004, 12:37 am
by babyblueMX3
Posted: July 24th, 2004, 10:52 am
by MX3ze@7psi
does it make a differnce?
Posted: July 24th, 2004, 11:26 am
by babyblueMX3
if a cat back makes a difference with a ze??...ohh yeah....I always said when you do a ze swap you should change intake exhaut..this my man is a breathing machine...you'll choke it with stock stuff
