klze in, but brakes are sticking now....?!
Re: klze in, but brakes are sticking now....?!
could your ebrake be stuck? Not the lever, but the part on your back wheel. Mine was, had to replace it and it costed like 300 bucks...
Tom Alexander
- mitmaks
is mazda equipped with proportioning valve? could be misadjusted proportioning valve.
Maybe you need to remove the caliper and free it off.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
- PATDIESEL
The rotor will rust and it probably rusted to the pad and just needed to be freed up.
