Upgrade air filter...
I was just ordered a K&N air filter and just realized it's the replacement filter, so I just cancelled that order. Now for my ???
What do I need if I want to put a cone filter and what size cone filter will fit best?
THX in advance.
PcE
B
THX in advance.
PcE
B
Re: Upgrade air filter...
PSI Tuning
Check out this site.
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Mad respect, thx for the link.
I was also looking at the FAQ's and found this to be helpful.
http://www.mx-3.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=23&t=000006
All I needed was these items....
2 x 3" to 3" Silicone Adapters (Plumbing section) - $9 each
(If you can find a 2.5" to 3" get one of each instead)
1 short aluminum wrapped thin 3" to 3" silicon adapter - $6
4 Foot section of black PVC Tubing 3" Diameter - $6 (white is available too)
90 degree bend PVC Tube - $5
The K&N or brand of your choice cone filter - About $50 at any speed shop
Total Cost : $85CDN ($55USD) with filter, only $35 ($25USD) without it. I told you I was cheap!
Once again, thanks for the link, it was VERY much appreciated.
PcE
B
PcE
B
sorry for being such a newb...
http://www.psituning.ca/catalog/product_info.php?cPath=21_27&products_id=45
looking at the link, this only covers the tubing and I'll still need to buy a cone filter, correct?
If so, back to my orginal ???, what size cone would I need or which cone would be better to get?
thanks once again in advance....
PcE
B
PcE
B
Thats for a CAI, if u dont want a cold air intake, take a measuring tape and measure the inlet size, then get a clamp and cone filter to fit
I'd rather get a CAI for $130, it should perform better, should it not cuz it's gettin cold air rather than hot engine air?
Any suggestions on size of cone?
PcE
B
PcE
B
No Idea, I still dont have a CAI for my car. I just got the stock box.
Kept my stock airbox too on 1.6 DOHC and just dropped in a fabricated foam filter, similar to the MazdaSpeed one @corksport (only mine cost $6 to make) . Anyway, decided to keep this modified foam filter in the stock airbox instead of installing a CAI because I like the design of cold air feeds on the stock intake configuration. Dunno about the stock SOHC but on the 1.6 DOHC airbox there are already two cold air inlets, one under the hood/upper grill area and a second one bringing cold air from the fender well. Seemed like too good a setup to mess with beyond adding a the drop-in foam filter. Very pleased with increased throttle response at all rpms and especially from 2800 - 4500+ rpms. Dunno tho how it stacks up to an all-new CAI... my .02.
I followed much the same logic, except I stumped up for a K&N replacement filter element. I think you get 90% of the benefit of the cone filter and Home Depot cold air trunking for a lot less hassle. I've just done the same thing to a 16V Suzuki X-90, and the difference in torque (even at low revs) is remarkable.
I agree it doesn't look so good, but I drive with the hood down
Is this a wise purchase, or is it false economy.
I note the words "Mazdaspeed-STYLE" in the auction...
Bearing in mind I know NOTHING at all about this kind of thing, how hard is it to fit/install and indeed is it even suitable for my car (standard V6)?
- jschrauwen
I think this will prove very helpfull.
http://www.mx-3.com/phpbb2/viewtopic.php?t=41026
I am a big fan of K&N and used the replacement filter in the stock airbox for 10 years before changing to CAI. I believe in order to realize the benefits of COLD AIR, the cone filter must be located in the fender well hollow. You can't go wrong when chosing a K&N cone filter either.
My recommendation would be to pick up one of the very inexpensive 91-93 Integra off of ebay (the 2 piece aluminum 0ne) from anywhere from $15-$20 usd + about $30-$35 shipping. Cut the tubing to the size you want to fit in the fender well. You'll probably need a couple of additional couplers to supplement the ones provided in the kit, but that's about it.
- mitmaks
this was discussed before which is best intake setup. Just last week, you can search.
Or, alternatively, I could read the link jschrauwen posted two posts before yours which is, in fact, the exact same thread you're talking about.
And indeed, as I said, "Interesting thread - pity I could only catch one word in three of it..."
And furthermore my original question was whether the particular filter I posted was any good and how hard it would be for a total novice (that's me) to fit, and not the best place to position a completely different company's filter with all sorts of mechanical jiggery-pokery.
And of course to dig this thread up - titled "Upgrade air filter" (exactly what I intended doing) I did have to search a bit.
But cheers for the help.
Edit: And this is quite a nice walkthrough. Except for the phrases "Uncouple the VAF" (what the smeg IS a VAF) and "Simply relocate..."
