scoop
- goldsberry1
scoop
hello, i was debateing on putting some type of hood scoop on, to feed my intercooler. i was thinking of puting it right where the radiator fill tank on the drivers side is. so the scoop would be right over it. but i'm not sure how it would look. or should i just think of the perfomance insted of looks? do you think it would get enough air flow there? thanks for any help you all can give.
92' mx-3 gsr, built engine, forged internals, p/p ze heads. t3/t4e .63/.60 turbo, udp, msd ignition, millenia s injectors, millenia im, water cooled intercooler, afpr, fmu. running at 7 psi right now
Re: scoop
why don't u just get a Front mount intercooler?
- goldsberry1
Re: scoop
well i was going too, but i was trying to go with the shortest amout of intake pipeing i can to reduce pressure drop. but i might eventually go to a fmic. they are more efficent in cooling, but they also have more pressure drop too. so i guess its a trade off
- PATDIESEL
Re: scoop
I think that their benefits out weigh their pressure drop by quite a bit unless you are running very low boost.
- goldsberry1
Re: scoop
i might try to go with fmic. i will have to wait and see how the rest of it goes.i just wish i had someone close by here that had a turbo mx3 already done so i could have some help in routeing the tubeing for the fmic.
