some help please!!
Posted: July 10th, 2004, 10:21 am
by DJester187
i know this is a repost but i didn't get any telp the first time. so while idling i can slowly feed fuel to the engine to steadily raise the rpms, but once it reachs exactly 2 1/2 rpms the engine drops rpms to 2 then back to 2 1/2 and will continue to keep bouncing until i let off the gas. Then if i push the engine higher than the 2 1/2 mark it will stall when i let off. any info?
![Sad Wavey :sadwavey:](./images/smilies/sadwavey.gif)
Re: some help please!!
Posted: July 10th, 2004, 10:41 am
by johnnyb
did you recently do any intake modifications? If you have make sure you plugged in the MAF that would cause your problems
Posted: July 10th, 2004, 10:46 am
by DJester187
well i did so an intake mod. but i plugged the harness back into the vaf. should i go back to my stock intake? i'd rather not.
Posted: July 11th, 2004, 4:16 pm
by hgallegos915
that sounds like a disconnected maf o.0 but could be a vacumm leak. Have u pulled codes?? checked fuel pressure?
Posted: July 13th, 2004, 2:48 am
by Tempus
once you've made sure that the VAF is properly hooked up, you might make sure everything on your intake is 'airtight'.
If you have any air leaks engineward from the VAF it could thow off the VAF's ability to get an accurate airflow reading. So I'd start looking, starting with where the VAF attaches to the intake and make sure everything is properly connected, and no loose fittings, cracked rubber, etc.
