What's everyone running for a manifold on their KLZE?
Like the subject says. Just wondering what you're all running for an intake manifold. I have my KLZE, unfortunatly it came with a stright neck manifold. So I guess I can get a curved neck or use the 1.8L manifold.
Just wondering what everyone is running and why?
-Golli
- babyblueMX3
Re: What's everyone running for a manifold on their KLZE?
millenia 96 mani. here
RIP 400whp ZE-T MX-3
curved ZE
91 Eagle Talon Tsi AWD *RIP*
Straight neck ze cut and welded.
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
14.385 @ 98.21
curved millenia ze
- papa roached
97 millenia
- Sam Baker
stock K8
until my curvy neck comes
<small>[ July 05, 2004, 10:51 PM: Message edited by: Sam Baker ]</small>
92 Autozam AZ3
curved neck MS8 manifold w/1996 Millenia Throttle body on outlaw spacers. Custom CAI I made from a 91 civic Si intake tube.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
*cough* 94 millenia curved
![Image](http://i95.photobucket.com/albums/l129/oursdekoala/avatar_nov3.jpg)
GS-R SE
Fixin's
i used the strait neck mani but i re-routed the brake fluid container and i hade to shave some of the throttle linkage but its been working great for me
MS8
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Straight neck
My Cardomain site
My Cardomain site
'94? Is that a Jap spec?Originally posted by mdavis:
is the k8 manifold really restrictive? because i was thinking about using this with my klze because ill be using the k8 ecu...
what kind of car IS that?
Yes, the K8 is the smallest diameter runners of all the K intakes, whereas the Millenia and KLZE have the largest, with KLDE and KFZE intakes bing in the middle.Originally posted by Patrick Halacy:
