Problem with starting car in first gear
Posted: June 19th, 2004, 7:35 pm
I always park my car in first gear with the parking brake on. Lately, when I've started the car by pressing the clutch and brake while in first gear, the engine will start and abrubtly begin to vibrate badly and then cuts out and stalls.
This only happens when the engine is cold; if I make several trips in one day it will successfully start in first gear each time, however if I leave the car parked overnight and try to start it then, it stalls.
Also, it wont stall if I start the car in neutral and this is what I've been doing lately.
Can someone tell me if this is a clutch-related problem?
