does anyone know the thickness and bore of klze head gaskets like the stock ones???
need new ones asap
klze head gaskets
klze head gaskets
1992 MAZDA MX-3 GSR 2.5LTR V-6
2005 SUBARU STI
2004 NISSAN ARMADA
http://www.cardomain.com/id/wkdmx3gsr
http://www.netuners.com
2005 SUBARU STI
2004 NISSAN ARMADA
- papa roached
Re: klze head gaskets
just use proge gt 2.5L head gaskets
You can use any Probe/Millenia/626/MX6 gasket set for the KLDE.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7905281526&category=46098&sspagename=WDVW
there are different sizes and i don't want to change the thickness at all want everything the same. thanks for the help anyways
2005 SUBARU STI
2004 NISSAN ARMADA
2005 SUBARU STI
2004 NISSAN ARMADA
ummm no- all 2.5's use the same head gasket
91 Eagle Talon Tsi AWD *RIP*
