Can anyone tell me which wires on the distributor are the RPM sensor and coil + and - ?
I believe they are as follows but I need confirmation:
3 Pin Connector
Blue = Coil +
Red = Coil -
Yellow/Blue stripe = Tach/Instrument Panel
Anyone?
Distributor Wires on K8
Agressive1
My fiance won't let me touch her GS! I am allowed to wash/wax it though.. Hmmmm...
Re: Distributor Wires on K8
Yes, you are correct:
Blue - Coil Primary from Ignition (so +)
Red - Coil Primary to Ground (so -)
Yellow/Blue - to tacho
