PRC Valve Vacuum Hose
Grhodes18
Post by Grhodes18 »
The vacuum hose that goes from the fuel Pressure reg to the PRC Valve solenoid, has what looks like a silver BB at the solenoid end. Is this right? Air will not pass in either direction.
TsiMiata
Re: PRC Valve Vacuum Hose
Post by TsiMiata »
Just ditch that solenoid and run the FPR right off the intake manifold vacuum. It is only there for when the car is warming up. I noticed no difference with it hooked up VS. disconnected. I've removed this solenoid from several different makes of cars with zero trouble.
91 Eagle Talon Tsi AWD *RIP*
