Is this the 195hp 2.5L?
Is it easy to tell whether a particular 2.5L is the 195hp version?
Any possibility that you guys can tell whether this is the 195hp version?
<img src="http://pirate.shu.edu/~finleyro/klze.jpg" alt=" - " />
<A HREF="http://www.finchuck.com" TARGET=_blank>Finchuck Online</A>
Re: Is this the 195hp 2.5L?
Thats the curved neck eunos 800 / xedos 9 engine. Rated at 196hp and reaches its peak torque at a lower rpm due to having kl01 camshafts. (straight neck ze's have kl31 cams which are more agressive).
DONATE TO MX-3.COM
DONATE TO MX-3.COM
How does this one compare to the other 2.5L's out there?
BTW/ Thanks for your very detailed insight![Smile :)](./images/smilies/icon_smile.gif)
As long as it has no egr valve and upon opening the tb you should see a knife edged divider in the middle, that is the motor I have in my car and it works fine low end torque is never a problem
. Cars looking good Gro(not to thread jack).
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
- papa roached
or how about a ZE with kl31 cams that someone put a MS8 on so it would fit in a MX?Originally posted by Gro Harlem:
Ms8 is a mx-6 but anyways the kl31 cams just shift the power higher in the powerband, as the kl01 cams make it lower in the powerband, this has been discussed dozens of times by me personally so there is a lot of info you can search for :p
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
[quote]Originally posted by finchuck:
go to my web site, the answers are there.
![Werd :werd:](./images/smilies/werd.gif)
Yes, I AM a bastard
Yes, I AM a bastard
Yeah I know. I sold my MX-3 freshmen year of college, now I'll be a senior and I'm thinking about buying that KLZE MX. So that's why I've been gone so long. I never realized that I was member # 117, I didn't know that I came that early in the game.Originally posted by curtklze:
Incorrect, the MS8 isn't remotely related, or a "twin" of the MX-6. The Japanese MX-6's are called "MX-6 Mystere". The MS8 looks like a slightly larger, upscale 626 sedan and came only in that body style.Originally posted by lazzyie:
I'm in the process of writing a page showing the different cars all of the K-series came in with pictures. Mainly b/c i'm so sick of people saying MS8's are MX-6 twins & eunos 800's are millenia twins (close, but not quite true either...the millenia's didn't exist back in early 93 when the eunos 800's were introduced).
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Yes, this is an Efini MS-8:
<small>[ April 26, 2004, 03:30 AM: Message edited by: IanL ]</small>
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
what is the difference between the curved neck Ze and the other one (straight neck or something)? ![Froggie Red :froggie_red:](./images/smilies/froggie_red.gif)
"For those 10 seconds or less, I am free"
It means the intake manifold is either curved or straight. Straight comes with the KL-31 cams and curved comes with the KL-01 cams. The main problem for us is that the straight neck mani won't bolt up in our little cars without more modding than it's worth. That's why you either go with the curved from the start or buy a straight then a curved mani to swap onto it.
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
Yeah, the 800 and millenias are very closely related, but the earlier 800's that we get most of our curved neck engines from have a lot of differences over our USDM 95+ millenias. I still have yet to be able to find good pictures of a 93-94 eunos 800, only of the 98 model for my K-series FAQ.Originally posted by IanL:
If you look one place up on the ad you will see a mention of Eunos 800 (Mazda Millenia), so I guess the used car dealers aren't too fussy about accuracy![]()
DONATE TO MX-3.COM
DONATE TO MX-3.COM
This any good for you?Originally posted by Gro Harlem:
Or this ?
like I said..."Good pictures". that first link is one i've never seen before, but the picture quality is low. I want at least 400x300 pics for the faq. The last link is the newer style eunos, not the older 93-94 i'm lokin for
DONATE TO MX-3.COM
DONATE TO MX-3.COM
