I will be picking up my ZE shortly. Luckily I get to see and choose which one I get. Apart from the stampos what else should I look for to make sure I choose a good motor? Also how can I check the compression my self?
Thanks
What should I look for??
- 93-Spec-Edn
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
Re: What should I look for??
yes you can test the compression manually.
- 93-Spec-Edn
how do i do that? Is it easy? should it be 200psi on each cylinder?
