Which VAF
Posted: April 11th, 2004, 9:48 pm
by Talon_66
I just sat here searching for the last hour, and I couldnt find the post I was looking for. Anyways.
I was wondering which VAF is better to be running with the KLZE? The 1.8L VAF or the 2.5L VAF?
Re: Which VAF
Posted: April 11th, 2004, 9:56 pm
by Taras
JE50 VAF which is the one from 1.8 V6
Re: Which VAF
Posted: April 11th, 2004, 10:09 pm
by Talon_66
Thanks, I think thats the one thats on there. He took the Throttle body off my K8 Manifold.
Can't wait for the West Coast meet.
Re: Which VAF
Posted: April 12th, 2004, 12:20 am
by TsiMiata
You shoyuld be using the KLZE throttle body. The K8 one will hurt performance.
Re: Which VAF
Posted: April 12th, 2004, 12:23 am
by SimonPK
I run the KLZE TB, K8 ECU & KLDE VAF - I got fastpass on Aircare, plenty of power and mileage is around 32 mpg. Works for me!
Re: Which VAF
Posted: April 20th, 2004, 9:58 am
by cap4004
I also have the K8 TB (on the ZE curved neck IM). Is the TB from a KL-DE the same as from a ZE? What TB do I need so that I don't lose hp. (I can't afford one of the larger custom TB's, so it'll have to be something I can find off a US parts car.)
Re: Which VAF
Posted: April 20th, 2004, 10:01 am
by cap4004
This depends on what ecu you are using. If you have the ZE ecu, use the mx-3 VAF. If you have the mx-3 ecu, use the VAF from a KL-DE. If you use ecu and VAF from mx-3, you will run rich and get bad milage.
Re: Which VAF
Posted: April 20th, 2004, 3:55 pm
by Steeb
32mpg x 12 gallons = 384 miles a tank. that is 114 miles more i can go on a tank of gas. i get about 270 under normal not slow not fast driving.
the klde and ze tb diameters are the same. the klze straight neck iac will not fit the mx3 so u must find a curved neck manifold tb and use the iac it came with or try to swap your k8 iac to the tb u r using.
Re: Which VAF
Posted: April 20th, 2004, 5:21 pm
by Nd4SpdSe
I use a KLZE ECU with the 1.8l VAF, depending on how i drove, i get between 350-450kms a tank. I never broke 400km with my 1.8, so i actually get slightly better milleage witht the KLZE
i belive that the JE50 VAF is what is actually used in Japan with KLZE's
also a combo that i heard works is the KLDE VAF with teh KLDE ECU, i think killerpickle uses that combo
<small>[ April 20, 2004, 04:23 PM: Message edited by: Nd4SpdSe ]</small>
Re: Which VAF
Posted: April 20th, 2004, 5:32 pm
by mx3man83
I also use the kl03 ecu and vaf. Works wonderful for me.
