ok the 929 has a 3.0 v6, alot cheaper then the klze swaps, runs 200hp and 200ft.lbs at 3500 rpm.
question? does anyone know the dimensions of this 3.0 v6 cause if its similar to the
kl engines = 620x675x640
if the 3.0 is the same you could quite easily get alot more torque/hp out of this larger displacement.
any ideas?
3.0 V6 ... hmmmm
3.0 V6 ... hmmmm
- mitmaks
Re: 3.0 V6 ... hmmmm
im not sure if you could find that engine for cheaper than klze, I wanted to swap in millenia S supercharged 2.5L
i just found a bunch of 3.0 engines online in ontario canada running for about 400 bucks each.
- Zoso124
Just like the Millenia its too big and not worth the headache.
Mike Evans
Gone:
Gone:
It is an enormous engine. The other problem is it's RWD. It won't bolt to our transmisions.
91 Eagle Talon Tsi AWD *RIP*
the supercharged millenia is a 2.3litre
Tom Alexander
- papa roached
but its physically to big, the whole top end of the motor is setup differently
its a JE motor, ridiculously huge, and is mounted differently. No chance in hell it'd fit.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
