I got a new strut bar that I like but my car has
AC so I cant put the strut bar on because of the AC line that runs close to the tower.
what can I do?
/SIXPACK
problem with new strut bar and AC
Black '92 GS - Pacesetter QuickShift w. SRD Extension rod Bushing + bronzoil - Top Speed Pro1 exhaust - Hotshot style headers - GTS coilovers - 18" ADR Sokudo gunmetal, f+r strutbar, floorbar & SRD crossmember
- atlantamx3
Re: problem with new strut bar and AC
No Problem,
Run the strut bar under the AC line. It takes some jiggling, but it will work just fine.
![Welder :welder:](./images/smilies/welder.gif)
- SE-Man
What I did was bent the metal part down next to the battery, when I put it over the strut bar the movement when i drove would prolly rub a hole in it, it was rubbing a bolt.
