is it worth it?????????
Qalex
Post by Qalex »
pulleys run anywhere from 150-200 and flywheels are approx. 300 do these really make enough diff. to drop $500, or is there some alternate route to gain horse other than the klze, headers , kl31 ecu, intake , plugs , wires,2.5 exhaust no cat and so on that i already have
klze, ze ecu, hotshot headers,2.5 exhaust, custom cai, plugs, wires,intrax lowering springs, crossdrilled rotors,eclipse deck with in dash 6 disc, 2 12inch jlw3, u.s. amp vlx25, and fosgate door speakers
papa roached
Re: is it worth it?????????
Post by papa roached »
they are about the only bolt ons that i know of for the K series motors save for what you already have
<small>[ March 07, 2004, 04:47 PM: Message edited by: papa roached ]</small>
