klze appearence
Qalex
klze appearence
Post by Qalex »
hey whats up guys just got my klze and it is about two days out from install just waiting for mounts and headers. only thing wrong is that the motor came kinda greased over on the manifold and i was wondering if you guys ever paint them or have a really good idea on how to clean them cause engine degreasers did not work!Thanks
klze, ze ecu, hotshot headers,2.5 exhaust, custom cai, plugs, wires,intrax lowering springs, crossdrilled rotors,eclipse deck with in dash 6 disc, 2 12inch jlw3, u.s. amp vlx25, and fosgate door speakers
Tyler17rose
Re: klze appearence
Post by Tyler17rose »
Sand them to a polished finish.
Mods:
Qalex
Re: klze appearence
Post by Qalex »
sand them with a high or low grit paper?
SimonPK
Re: klze appearence
Post by SimonPK »
start with high to get the rough stuff off and progressively go finer as it starts to shine - get yourself a power sander!
Re: klze appearence
but how do you get a power sander to squeeze between the tight spots?
SimonPK
Re: klze appearence
Post by SimonPK »
take a look at a Dremel type sander - just be careful not to let it dig in
Qalex
Re: klze appearence
Post by Qalex »
i thought about that but was worried that the sanding would give it a dull look, my old motor is the v6 k8 1993 and it looks a million times better from head to two it looks brand new
