which trans?
projectmx
which trans?
Post by projectmx »
I am hopefully buying a 94 mx3 with a 2.5L engien swap already done...however the third gear doesn't work so sometime soon i'll have to put another trans on the car.. i've been told i have two choices of trannys.. the one for the 2.5 or the stock one... what are some advantages or disadvantanges of either one.. any insite would be great.. thanks everyone
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
lakersfan1
Re: which trans?
Post by lakersfan1 »
I'd get one from an MX-6 so you could get the higher geared 5th gear for better fuel efficiency on the freeway.
projectmx
Re: which trans?
Post by projectmx »
is there a particular year that would be better? and wouldi have to switch to mx6 axles cause right now its an mx3 tranny with mx3 axles
ProjectMx
Cardomain
SimonPK
Re: which trans?
Post by SimonPK »
no axles are all the same except if you have ABS
Low3-XM
Re: which trans?
Post by Low3-XM »
would the mx6 tranny be good for all round driving on highway on the darg strip around town ... or just mostly for the long drives...
when i say drag strip i don't mean full blown out drag racing..
<small>[ March 01, 2004, 02:24 AM: Message edited by: Samm ]</small>
projectmx
Re: which trans?
Post by projectmx »
which trans is stronger? i'm guess the mx6 one from the talk but want to be sure.. and is there a difference between the mx6 trans and prob trans?
ProjectMx
Cardomain
projectmx
Re: which trans?
Post by projectmx »
if i switch from the mx3 trans to the mx6 do i need a different flywheel / clutch or anything like that?
ProjectMx
Cardomain
lakersfan1
Re: which trans?
The Probe transmission is geared exactly like the MX-3. The MX-6 is the only one with a taller 5th gear. Gears 1-4 are the same, though, so acceleration should be exactly the same on either until you get to that 5th gear. Since in drag racing, you'd be lucky to make it to 4th gear in the 1/4 mile, it woun't affect your 1/4 mile time at all.
The clutch and flywheel will transfer over fine, though you'd be silly to not replace the clutch while you're in there unless you just replaced it recently.
monstar-mx-3
Re: which trans?
Post by monstar-mx-3 »
I'm running a 1.8 iwth a 2.5 mx-6 tranny. Its a direct swap..easy to install. Its a great tranny.
babyblueMX3
Re: which trans?
Post by babyblueMX3 »
what are the differences?. I mean I do have abs but it never worked on the car..Can they still fit with my 1.8 tranny?
RIP 400whp ZE-T MX-3
