I got a 92 MX-3 white 2.5 KL (aka whitefish old ride)But I have no heat.I have changed the rad coolant and thermostat(180).Also changed the upper and lower rad hoses. But still no heat.It blows all cold air when I point the air to my feet and warm air from the vents but never hot even after driving for 3hours.
Does anyone know what I should do next?
clubnightspice#hotmail.com
No heat problem with 2.5 KL HELP!
- monstar-mx-3
Re: No heat problem with 2.5 KL HELP!
might be time to change your whole heating unit under the dash.
- wyldside
Double check the fuses first. You never know...
James Gosteli
X-Prez of MX-West
1992 Seal-Gray MX-3 GSR-ZE (KLZE 2.5L V6)![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
1992 White MX-3 GSR-ZE (KLZE 2.5L V6)
Worklog (Parting out)
1993 Blaze Red MX-3 GS - RIP![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
X-Prez of MX-West
- monstar-mx-3
Make sure you got the right mix of coolent and water. YOu need a tester for that. Its pretty cheap.
Another thing to check - the distribution flaps in the heater box which control the airflow.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
make sure the ducting is still on the blower, its under the dash of the passenger seat, mine was partially knocked off and was blowing cold air, that and the thermostat went
- Zoso124
Make sure there is enough coolant in the system. You know you fill it up between the heads and not the radiator cap. You gotta get all the air out of the system.
Mike Evans
Gone:
Gone:
