fuel gauge broken???... help
ovendenk
Post by ovendenk »
i've got a 93 mx3 v6 and my fuel tank has a leak. i'm gonna replace it but i don't know if i have to replace the fuel level sensor (or whatever it's called) as well.
whenever i go up a hill that curves right, my gauge says i've got no gas. it eventually returns to normal, but what the hell? it also take a REALLY long time for my gauge to settle after putting gas into the car.
is this a common prob or do i have to replace something else as well as the tank????
thanks,
kevin (http://members.rogers.com/kovenden/)
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
IanL
Re: fuel gauge broken???... help
Post by IanL »
My gauge also takes a long time to settle after refuelling. It is probably a "hot-wire" type, designed to react to longer term changes only, so that it doesn't wave around much as the car turns & dips. But it will react to a prolonged period away from the straight and level, provided the ignition is on. My guess is your gauge is working normally.
<small>[ January 14, 2004, 05:10 AM: Message edited by: IanL ]</small>
ovendenk
Post by ovendenk »
thanks man
