Horn stopped working. Any ideas?
jumboplay
Post by jumboplay »
Recently my horn stopped working. All fuses and relays checked, I hear it click when I try it, nothing happens. Any common problems with this? Also, where is the horn itself, since the online shop manual seems to have disappeared? :-\ . Any help would be appreciated? Or maybe I'm just low on horn fluid? Hehehe... :roll:
-Tom J, proud MX-3 pilot-
Get your entertainment upgraded at http://www.tommyv2.com
1996 MX-3 RS/GS hybrid, OBDII B6-ZE, painted Mazda crystal white, ZX-2+Eibach, Miglia Spyder 17"s, markerflash, black altezzas, insane fuel economy, too many other mods to list...
Taras
Re: Horn stopped working. Any ideas?
Post by Taras »
If it is clicking then it is your relay. You wiring must be fine. I would say the horn itself is damaged. May be got too much water. It is behind passenger side front turn signal assembly. May be a good time to upgrade to something better.
Taras
'92 GS Gray ZE
'05 Gixxer 750
MxWest VP
www.mx-west.com
DJsMX-3
Post by DJsMX-3 »
Measure the voltage at the horn,while having someone depress the honker :)
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
