Compression on KLZE
SimonPK
Compression on KLZE
Post by SimonPK »
When I fitted my KLZe a few months ago there was a label on one of the spark plug leads titled "compression value in bar". The numbers on the 6 cylinders are 39, 41, 42, 39, 40 and 41. I have no idea what these mean in PSI as I know that a KLZe in good condition should be around 200 psi.
Has anyone any idea what 40 bar means?
thnx
killerpickle
Re: Compression on KLZE
Post by killerpickle »
http://www.chromatography.co.uk/Techniqs/Other/Pressure.htm
found this
<small>[ January 04, 2004, 09:18 PM: Message edited by: killerpickle ]</small>
Tom Alexander
SimonPK
Post by SimonPK »
Thanks Tom - that's why I am confused as there is no way that a KLZE can have a pressure of 580 psi which is what 40 bar is! The tag on my engine was computer generated and says "Iveka" and "75417 Muhlacker"?
