Hey guys,
My engine light came on a few weeks ago, so I took it to the shop and they couldn't find anything wrong, so they cleared the computer and after a few days it came on again. $#@!#@$#$#!~!!!!
Anyone have the same prob?
Thanks
Engine light!!!
- marcus2966
Engine light!!!
Roll with it or get rolled over mother%@#er!
http://memimage.cardomain.net/member_img_a/478582_8_full.jpg
Re: Engine light!!!
Check engine light 90% off the time is O2 sensor. Sometimes it is a bugger in colder climates, I'm from edmonton so I've seen it lots.
What happens is the engine runs under the optimal temperature due to the cold climate, so the fuel is bruning inefficiently. So the computer says hey you don't have enough 02 to combust the fuel. Throw a light on the notify the driver. You may notice it will go off after you continue to drive and the engine heats up. In Edmonton it only happens intermittently on colder days say -15C and below.
But the O2 sensor can be affected by other things, not only operating temperatures. this is just the most common. e-mail me if this isn't the prob. I can give you further advice.
later,
mms1@ualberta.ca
http://www.cardomain.com/id/mazdamachine
later,
mms1@ualberta.ca
Re: Engine light!!!
any codes???? next time the CEL comes on do a diagnostics check. then look in the FAQ section for a listing of code deffinitions.
