klze electical help!!
i was just wondering if i could get some help from anyone out there. i wanted to know what parts of the klze wire harness and sensors needed to be swapped with the stock k8 motor. im not to sure but there were two big bundles of wires that were cut when the engone was shipped but otherwise the rest of the klze wire harness seems to be fine, im assuming that one of the bundles leads to the ecu. what should i do about the ecu connection? thanks
Re: klze electical help!!
Use the K8 harness.
Mods:
- Buff1110
use ur stock k8 wiring harness. i swapped over all the sensors from the k8 to the ze to make sure bc some people do and some dont and while both motors are out u might as well.
also swap the water inlet neck if ur ze has only 2sensors bc the k8 has 3 and if u dont swap it ur gonna have to install the temp sensor somewhere else and have to extend the harness to connect it,
Dan
02 Tacoma TRD - Daily
ah ic thanks a lot
