Car cuts off ou tof Nowhere need some extra advice...(De
UrBaNsTyLe55
Re: Car cuts off ou tof Nowhere need some extra advice...(De
Post by UrBaNsTyLe55 »
check your relay' and wiring and also your fuses, i had the same problem and it was because the wire to my relay was loose
92 323 KF-ZE V6 swap done by me 2 1/4 header back exhaust no cat car now for sale for very cheap! email me at queensnysfinnest@aol.com for pics and questions
Tyler17rose
Post by Tyler17rose »
Most likely your disty.
Mods:
curtklze
Post by curtklze »
isnt the coil inside the disty?
Yes, I AM a bastard
mitmaks
Post by mitmaks »
umm... i had this happen to 2nd gen eclipse we have. it was fuel injector.
UrBaNsTyLe55
are your spark plugs and spark plugs wires in good shape, that might cause it as well, also check your fuel pump and make shure its not shortening out on you, :froggie_red:
