Need some help
IvsD
Need some help
Post by IvsD »
The collector pipe (comes off of the exhaust manifold, "Y pipe"....)
<img src="http://www.boomspeed.com/gregr187/dp.jpg" alt=" - " />
Is it the same on the Probe GT as it is on the MX3 GS??
In other word, if needed, could you swap the Collectors from a Probe to an MX3??
The last piece of my puzzle..........I need to know!! Thanks
pelado
Re: Need some help
Post by pelado »
No. Probe, MX-6, and 626 are longer vehicles and the collector is also longer.
IvsD
Re: Need some help
Post by IvsD »
How much longer are we talking about?? Een worth attempting to fit it??
Jutzi420
Re: Need some help
Post by Jutzi420 »
You would most likely have to either remove your cat or do some cutting and welding. The latter is preferable for emissions.
