I'm not to familiar with what a complet clutch unit should include? Its a used Clutch masters 3 with a fidanza fly.
What I need to know is what should come with the clutch? a pressure plate, something about a throwout bearing and other ****. Can someone help me so I don't get jacked.
He says it has about 5000 miles on it.
Let me know!
Peace
WHAT SHOULD I ASK FOR???
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
Re: WHAT SHOULD I ASK FOR???
4 pieces - pilot bearing (fits in the flywheel hole in the centre), release bearing (bigger of the 2 bearings), pressure plate and cover. Check flywheel for scores, teeth on the outside not worn etc.
There are plenty of deatils in the on line manual as well.
Hope this helps!
Hope this helps!
forgot about the disk
THANKS GUYS FOR YOUR HELP!!! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
OSKY
You could always buy pilot and throwout bearings separately later
Thanks!Originally posted by JDM:
OSKY
