SWAP Done
tocixxx
SWAP Done
Post by tocixxx »
My swap is finished, but i´m still using K8 electronics. This ride is hell now !!! I love it.. Here is a pic of my finished project !!
<img src="http://www.tocauer.com/gallery/gallerie ... bau046.jpg" alt=" - " />
92 GS-R, RX-8 Lightning Yellow, Complete Aresspeed Bodykit
http://www.cardomain.com/id/tocixxx
Mazda Speed & Style Club Austria http://www.mazdaclub.at
Spydie
Re: SWAP Done
Post by Spydie »
congrats :2thumbsup:
C-MX-DA3
Re: SWAP Done
Post by C-MX-DA3 »
nice. that engine looks nice and clean. btw where did you get your oil cap from?, i been trying to find one for the my ze but have no luck.
koreanmx-er
Re: SWAP Done
Post by koreanmx-er »
man where did you get that motor it is so CLEAN!!! it must of cost you tho , if you dont mind i was wondering where you got it from and how much it cost to your door thanx
<small>[ October 21, 2003, 06:00 PM: Message edited by: koreanmx-er ]</small>
sold the mx-3 , bought 04 gtp comp g , from the smallest v6 to one of the biggest 3800 s/c FTW
gsrbomb
Re: SWAP Done
Post by gsrbomb »
Cool 2.5L ! Really clean ! Millenia KL or KLZE from a Eunos 800 ?
P.S. Don't run with the K8 electronics !
If it's a KLZE, put a KL31 ECU or SDS Stand Alone.
www.sdsefi.com
-1994 GS ENTIRELY STOCK, BUT NOT FOR LONG!-
gsrbomb
Re: SWAP Done
Post by gsrbomb »
Your OIL CAP is really cool
Where did you picked it up ?
tocixxx
Re: SWAP Done
Post by tocixxx »
The Oil-Cap is from Ebay- liek this one in the link
You must know almost all Mazda have the same size for the oil caps.
Oil -Cap
I used brake cleaner to clean the engine and i painted it with a special silver spray that is used for old steel rims. It helps wonders.
The engine was picked up by a local importer of japanese engines. out of a Eunos 800.
13flat
Re: SWAP Done
Post by 13flat »
when you do the swap, do you have to do it yourself...if so, how do you get the tools to do it? or do you just have to have that friend thats really into cars help you out?
Goal: 1/4 mile time of 13.099 or better, N/A. ...still in the works
http://hits4pay.com/members/index.cgi?ittfund
Gro Harlem
Re: SWAP Done
Post by Gro Harlem »
I did my swap with the rental of an engine hoist, some jackstands, and a $50 mechanics toolset from wal-mart (stanley makes the best tools!) I've done about 6 motor swaps with the same amount of tools and with minimal help of my friends.
The only time you really need help is removing and lowering the motor into the car....you want to be sure someone operates the hoist, and someone else guides the motor inside without smashing into your lines, wiring or brackets, etc.
DONATE TO MX-3.COM
papa roached
Re: SWAP Done
Post by papa roached »
now you need an intake
tocixxx
Re: SWAP Done
Post by tocixxx »
why should i need an Intake , mazda did a good job by designing the Air Intake. Every intake which is not shielded gives you less power because of the heat. The only thing i could do is to replace the flex hose with a SS one and du a custom Cold Air intake. This would give me maybe 1 - 3 whp but not more. yeah and good optics
lazzyie
Re: SWAP Done
Post by lazzyie »
Nice clean setup, good job!!
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
