VAF
Posted: September 24th, 2003, 3:42 pm
by Blueman
Please help me find the VAF sensor on a 1992 MX-3 2.5. I only see reference to the MAF in the online shop manual.
Re: VAF
Posted: September 24th, 2003, 4:40 pm
by lakersfan1
I was under the impression there were no VAF on MX3's, or any K engine for that matter until like 98.
Re: VAF
Posted: September 24th, 2003, 5:04 pm
by Blueman
I see several references to changing out the VAF after the 2.5 swap.
Re: VAF
Posted: September 24th, 2003, 9:29 pm
by Blueman
OK, I really need some help here. I have completed the 1.8 to 2.5 swap in my 92 MX-3 and have already changed the ECU and I'm trying to change out the VAF but can't locate it. It's not listed in the online shop manual. All I see is MAF in manual.
Re: VAF
Posted: September 25th, 2003, 2:43 am
by mazdamaniac
Huh? You managed to do the swap but you don't know where the VAF is?
You know, you removed it to get the motor out in the first place.
Do you know what the VAF is?
Try the Volume Airflow Sensor on page F2-95 to start. Its item 5.
Re: VAF
Posted: September 25th, 2003, 11:06 pm
by Blueman
Thank you so much for your help. It's where I thought it was but everyone kept telling me that was the mass air flow sensor. Again thanks for your help.
Re: VAF
Posted: September 26th, 2003, 7:56 pm
by IanL
I don't think that's right:
MAFs were fitted to Millenias (2.3 KLJ and 2.5 KLD) from 95 to 98.
VAFs were fitted to MX-3s (1.8 K8D) from 93 to 98, and 626s and MX-6s/Probes (2.5 KLD)from 93 to 96+.
