Ok I have read and read and read, but know where has anyone got together with the best tunning configs and posted them... So lets post what you KLZE is currently tunned at and what the performance is like.. Mine is running like crap but here is what I have it all set at:<p>Timing: 10 degrees
TPS: .60 volts
Fuel Pressure idle: 43psi
Spark Plugs: ZFR6F-11(thinking of going to ZFR7F-11)
Spark Plug Wires: NGK<p>What you guys got??
KLZE Best Tuning Configs
Re: KLZE Best Tuning Configs
I am currently running a:<p>1. ZE
2. longneck manifold (shortened) + new gaskets
3. K8 ECU (KL36 on the way)
4. KL02 vaf (k8 vaf waiting for ze ecu to arrive)
5. Crane Cams ignition with external coil
6. ZE throttle body (k8 linkage, due to intake manifold)
7. I bent the tabs on the throttle body (where tps connects) so I have more play, otherwise I could only adjust it to the farthest setting.
8. Accel 8.8 wires
9. ngk plugs
8. Accel 8.8 wires
9. ngk plugs
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
14.385 @ 98.21
- babyblueMX3
ze
96 millenia IM
kl31 ecu
phenoloc spacers
UR underdrive pulley
shaved FW to 13pounds
custom cold air intake<p>car is running like a new one...no probs
96 millenia IM
kl31 ecu
phenoloc spacers
RIP 400whp ZE-T MX-3
This is the info I was looking for:
Timing: ? degrees
TPS: .? volts
Fuel Pressure idle: ? psi
Spark Plugs: ?
Spark Plug Wires: ?
KLZE Ecu: ?
Any codes: ?
Thanks![Wink ;)](./images/smilies/icon_wink.gif)
Timing: ? degrees
TPS: .? volts
Spark Plugs: ?
Spark Plug Wires: ?
KLZE Ecu: ?
Any codes: ?
Thanks
Hp- If you've done a dyno run & 1/4 mile times would be helpful to
91 Eagle Talon Tsi AWD *RIP*
