Page 1 of 2
will the KF-ZE fit?
Posted: September 4th, 2003, 9:30 pm
by ilovemymazda
will the kf-ze from corksport fit into my 93 gs without me having to replace anything. i blew the engine because it was low on oil. so is it worth it to get the 2.0 or should i find another 1.8. i really want my car back soon so help me.
Re: will the KF-ZE fit?
Posted: September 4th, 2003, 11:35 pm
by Custommx3
again, wrong. :) <p>tha KFZE will work just fine, I have one. Just talk to Lazzie and get the right ECU and it'll work just fine.
Posted: September 5th, 2003, 12:43 am
by MazdaManiacMx3
Dj Continum Please read up , I know you are new just don't post wrongful information if your not sure , Kl-ZE's are not alot of problems they are more work , But what do you expect out of a hybrid setup .
Kris
Posted: September 5th, 2003, 1:51 am
by UrBaNsTyLe55
hey custommx3 how does the kf-ze run any strong points about it, and do you need the ms8 ecu to run it or can you use the mx-6 one, i to have a kf-ze haven't finished instalation yet into my protege
Posted: September 5th, 2003, 2:05 am
by Custommx3
you HAVE to have a KFZE ECU.<p>I'll probably be using a 1.8L IM untill I can get a KFZE one thats curved. Or I may modify the car to use the straight neck KFZE one.<p>Image<p>[ September 05, 2003: Message edited by: Custommx3 ]</p>
Posted: September 5th, 2003, 2:22 am
by lazzyie
We will soon find out if that is the right ecu for the kfze because I will be mailing one off in a couple days... the KF manifolds I have seen are sooooo close to the k8 manifold. Oh and to correct whoever said the ze swap is harder than an 03(DE) swap is wrong all 3 motors are basically the same....
Posted: September 5th, 2003, 4:22 am
by dPmunky
why is the kl-ze more work? i dont get it, but for me the ze is worth the work for the 40hp
Posted: September 5th, 2003, 10:20 am
by Custommx3
Well, the distributors have to be swapped (cause its stock with an external coil on the KLZE and the KL is the same distributor as the K8.) Also the ZE doesnt have the EGR setup, the KL does. Also the engine coolant temp sensor on some have to be swapped over (drilled and tapped).
Posted: September 5th, 2003, 3:57 pm
by 2RotorsNaDream
dP its not 40hp its 70hp so yes its worth it.
Posted: September 5th, 2003, 5:28 pm
by UrBaNsTyLe55
so i couldn't run my kf-ze with my mx-6 ecu
Posted: September 5th, 2003, 5:30 pm
by Custommx3
Nope.. will run like crap, if it will run.
Posted: September 5th, 2003, 8:16 pm
by curtklze
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Custommx3:
you HAVE to have a KFZE ECU.<p>I'll probably be using a 1.8L IM untill I can get a KFZE one thats curved. Or I may modify the car to use the straight neck KFZE one.<p>Image<p>[ September 05, 2003: Message edited by: Custommx3 ]<hr></blockquote><p>hey man, what happend with the MAF, did you use the KF MAF or did you use the K8 JE50 VAF?<p>[ September 06, 2003: Message edited by: curtklze ]</p>
Posted: September 5th, 2003, 11:52 pm
by UrBaNsTyLe55
so where can i get the kf-ze ecu, and for how much
Posted: September 6th, 2003, 12:22 am
by lakersfan1
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by UrBaNsTyLe55:
so where can i get the kf-ze ecu, and for how much<hr></blockquote><p>Do a search. I believe Lazzie can get them. There's also a guy in NZ or AUS (can't remember) who I believe can source one for you.
