KLZE idle too high
Posted: August 27th, 2003, 4:19 pm
Hi, I just finished installing my ZE. It runs fine and I have no CEL. The only problem I have is that it the idle speed is too high. I played with the AAS screw on the TB but the lowest idle speed I can get is 3000 RPM. If I unplug the IAC valve connector the idle speed drop to 2000 RPM. The idle speed is stable. Here is some info about my setup:<p>- Curved neck KLZE
- Curved neck IM
- ZE TB
- ZE injectors
- K8 ECU
- Swapped the K8 EGR system on the ZE
- Curved neck IM
- ZE TB
- ZE injectors
- K8 ECU
