WD-40 VS BELT DRESSING
Ok, I actually heard you could put either on your belts to prevent squealing. Will any of these products cause damage to your belts? ![Shrug :shrug:](./images/smilies/shrug.gif)
Re: WD-40 VS BELT DRESSING
I used wd40 on mine for a while and nothing happened. If you know someone who could tighten the belts, it will probably get rid of the sound though.
- monstar-mx-3
you can buy a belt dresing spray for oyu local auto shop.
its actualy really easy to toighetn the belts cause there is a bolt that puts tention on a pully. follow the belts and you will see a pully with nothing atached to it but a long bolt. If you tighten it, it will put more pressure on the belt
is this solution temporary? how much should you tighten this bolt? will the added pressure cause the belt to snap? does the bolt have an easy access and has anyone actually done this?
- Custommx3
- Site Administrator
ID say tighten the belt, if not, use dishwashing soap... you think Im crazy, but im serious, it works.
- guyaverage
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr> Ok, I actually heard you could put either on your belts to prevent squealing. Will any of these products cause damage to your belts? <hr></blockquote><p>Your belt is squealing because it is probably ALREADY damaged. Too many miles on a loose belt, even a newer one, causes it to get a shiny, hard glazed surface, which rubs on the pulley as it rotates, causing a squeal. Replace it with a new one, adjust it to the proper tension, drive about 5-10 miles, retension it again, problem solved.<p>Wd-40, belt dressing, soap, tranny fluid, etc will all quiet it down, for a while.....but ultimately what you really need is a new belt, properly adjusted.
"The answer is: More power. I dont care what the question is."
-Tim Allen
-Tim Allen
- Custommx3
Not entireley true. My brand new belt, tightedned down to factory specs steal squeaked due to the residue on the pulleys them self from a leak I had. The soap helped remove the residue.
- guyaverage
In that case I would have used soap too, provided whatever was leaking was fixed first and the belt was relatively new. I was just going on the assumption his pulley was "normal" (no residue, properly aligned, nothing leaking on it, etc). I'm just not a big fan of putting lubricants and sprays on belts to quite them down when usually (not always) its a shiny, glazed, misadjusted belt that is the problem. ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
-Tim Allen
-Tim Allen
anybody wants to donate to the I need a new belt foundation?
300$ Is all I need :p
Which belt do you need? Drop me an AIM, I can probably get it cheaper.
the belt is cheap it's the labor thats going to cost me... (replacing the timing belt)
Hey actually wd40 is not good to use on any rubber products it has kerosene it ot over time it will eat and destroy rubber .
Just a little something to know
Kris
Kris
93 Kandy Tangerine Mx3 GS-DE
05 Saab 9-2x (Wrx power plant)
02 Subaru Impreza OBS
05 Subaru forester Xt - sti mods
04 dodge ram - toy hauler -FOR SALE
& Lots of Toys to haul![Very Happy :D](./images/smilies/icon_biggrin.gif)
- cjthor
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by blkmx3_v6:
the belt is cheap it's the labor thats going to cost me... (replacing the timing belt)<hr></blockquote>
Ummm no I dont think you want to put anything at all on your Timing belt. Replace it.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
i think your right about the wd-40 a friend of mine just told me the same thing...well its all taken care of now. I was coming back from Adams Morgan in MD and my belts just started squealing like crazy, lucky for me I made it home without any damage. The next morning I knew I had to get it fix so I prayed all the way to high teck. I realized it was the alternator belt b/c my warning signals started blinking all of a sudden, oil, battery, brake. I ended up replacing two belts: alternator and power steering. It runs squeal free and it only cost me $180.00. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
