throttle cable
throttle cable
I was wondering if any one had pics on how to route the throttle cable on the ze. Mine seems to be in sort of a bind and i need to reroute it. Thanks for any help, Steve
65 shot > V8
Re: throttle cable
It would be nice if someone would help. What bracket did everyone else use , i know you hae to do a little cuttin just need a little direction, thanks steve
65 shot > V8
- Zoso124
Re: throttle cable
Try using the bracket off the K8 manifold. Its not very hard to hook it up either way. You don't need to cut anything.
Mike Evans
Gone:
Gone:
Re: throttle cable
I used the bracket which came with my ZE - it's good and smooth action but the cable runs at 30 degrees to a straight line. Also the nuts which adjust the length are at the maximum. Getting this sorted out is on my list of around 15 little things to get perfect after the swap last week - Simon
Re: throttle cable
I am using the bracket from my k8 because some ****ing idiot threw out my other one that came with the ZE. I dont get full throttle but I am going to get a new bracket. Use the ZE bracket!
